ok bad1, here's some pics - here's my 58 -
the \'setback\' on the inner - is yours mounted in the same relation to that 'hump'?
here\'s the shroud I rigged for it, note that even w/ 5" of shroud it still needs the fat spacer behind the fan to put it in the shroud, so a 2" one sure wouldn't work for a 6cyl truck - I'm pretty sure the rad in the 58 is original and the only ID on it is a welded style tag w/ "3135642", which sounds like a GM or Harrison number
this rad is the original from a 57 panel w/ a V8, note the H-55 means it's a model 55 rad made by Harrison who made most all 55-57[at least] rads - any rad I've seen in these trucks that had any ID on were Harrison 55's, although
this spare one says G-55, but has the same part no.[?] as the V8 one, and different than the 58
all 4 rads I've currently got are identical configuration, and all that I've ever seen for any TF year are that same config - can't really recall off hand if I've ever run across a V8 58 or 9, but I can't see them designing a new rad for such limited use
help any :confused: ?
