0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 15 New Guy | | New Guy Joined: Jul 2009 Posts: 15 | Looking for an original (as possible) steering column for my 66... Will any steering column from 60-66 for the automatics work??
I had found one but realized later it was for a standard column 3 speed... I'm from the camp that nothing is IMpossible, but converting it is out of my realm. | | | | | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | Hello, Try posting an ad in parts wanted. I'm sure someone will have one. I would think 60-66 would work but I'm not positive. I'm not sure about converting one either. My truck is a 60 C10 and originally it had a manual transmission with a column shifter but it's automatic now. It does have the original column I think with the gear lever removed but the automatic shifter is on the floor. It looks like a 4 speed because the clutch pedal is still there too, but not functional. The work was done by the PO so I'm not sure what was involved. Joe
54 Triumph TR2(rhd)needs total resto. 60 Apache 10 stepside shortbed 99 Excelsior Henderson | | | | | Joined: Jun 2006 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 75 | if you are able to go to your local wrecking yard look at the steering colums. there is a difference where the linkage is.
"you can't fix stupid"
