1 members (klhansen), 101 guests, and 1 robot.
Topics128,151
Posts1,056,999
Members48,460
1/2 tons in decent shape are scarce and overpriced, so I got this one-ton 3600 with virtually no rust and only very minor damage to the passenger fender for $1,200.
All the glass is cracked, needs some trim and wiring, but it does have a 1969 255 HP 350" V8.
It also has an electrically operated 8' flat dump bed, cool for me as I want to use the truck to carry some of my smaller cars to the body shop.
I will mount a winch to the front of the bed, and angle it for easier loading.
Biggest issue with this truck right now is wiring and the wheels/tires.
I have two dually 17.5" wheels that are not on the truck but came with it.
It is sitting on single wheel type rims.
The rear are OK, the front sit out too far and rub the fender arches.
So I have to figure out what to do for wheels.
I'm thinking of going to fat singles in the rear, but I still have to find some front wheels with a correct off-set.
I will also need a spare that can be used at either end.
What is out there without spending silly money, or having a size that cannot be gotten if needed during a long drive?
And, what is a "3600", exactly?
So far I do not see any of this model shown in this forum.
I will add some pics later.
1957 Chevy 3600
At these prices I want my gas 100 octane, leaded, and my windshield washed!
3600 is a 3/4 ton.
Bill Burmeister
Welcome to the neighborhood. I'm not real knowledgable about rims. If your hauling, be sure to research the load ratings of the tires you're going to use.
I learn something every day Longbox55. I would of guessed 3600 was a 1 ton. Thanks.
Dave.
What's the last thing a red neck says, "Hey guys watch this."
What's the last thing a redneck hears, "Go ahead Bubba, you can do it."
Build plan: 65 Chevy one ton, 5.9L Cummins HO, NV5600 six speed, 2wd 1972-1987 IFS disk front, frame off restore/mod, custom dump/flat bed, Alcoa rims, Dana 70 3.73:1 duals drum rear, plush interior, Guards red with Marine Corps decals. Donor is retired 2002 Ram 2500, 194K miles.
3/4 ton with 8 lugs and the wide hubs in front which require the dually type wheels?
I suppose that might explain the short bed?
I think this may put a crimp in some of my plans, but the body is pretty good, so I guess I will continue on with it.
1957 Chevy 3600
Dual wheels were an option on 3/4 ton. I've seen 3/4 tons with duals all the way up to '72, though it is not very common.
As far as the frontend goes, you can remove the duallie adapter, which is hust bolted on, and run standard wheels. As far as a tire suggestion, that would depend on how wide of a tire you want on the rear. Then you get into load ranges, as many of the lower profile tires do not have the load range for that heavy of a truck. If you want to stay in something reasonable and easy to find, I would suggest a 245/75/16 E load range, very common size, roughly a 30" tall x 9" wide tire. A 265/75/16 E range may also work, not sure about front clearance. Those are roughly 31" tall x 10" wide. You'll need wheels with about 3.5-4" backspace to fit properly, pre-'87 4x4 should work fine. Another option would be to check into the later model Duallie wheels, run themw with the adapters and perhaps a 235/75/16, some also run 17s on the newer ones. I beleive they should clear the rear brakes on a 3600.
Bill Burmeister
Are you sure of that?
I pulled a wheel off, it looks like I would have to change hubs entirely to me.
1957 Chevy 3600
I've seen 'dually adapters' but the factory setups I've seen have always been a complete hub. The adapters I've seen were all after-market stuff.
That's not to say the factory never used an adapter, just that none I've seen were done that way.
At the moment it looks like I may just have to buy two 8-17.5 tires to fit the only dually rims I have.
They came with the truck, and they do work properly for the front.
I have some old eight spoke 31-10.50X16.5's that seem to be good enough to use in the rear.
The only problem with this is that it leaves me without a spare to fit the front.
$300.00 for tires to fit front rims I will probably not want to keep.
So I'm still looking at other options.
1957 Chevy 3600
With the Task Force trucks, all of the dual wheel trucks I've seen had an adapter. One in particular was a '58 3800 that I raided for parts, it was a factory duallie with a platform bed. Might have been an on again/off again deal.
Bill Burmeister
As I think about it, I don't think I've ever had a TF dually truck apart, so I can't speak to how they were built.
Richard, I'm pretty sure the factory dual wheels on your truck would have been the fairly common 16 inch type with four hand holds.
It should not be too hard to find a set of those somewhere. I'd search for someone taking them off to replace with custom wheels. You might find a set of six with good tires for nearly nothing just setting in the corner of someone's garage.
So far, all I have found are split-rim type.
Still looking!
1957 Chevy 3600
Look at newer wheels. You can use wheels from the 70's and 80's and they won't look much different than what were original.
OK, I may have an answer here.
I found a local wrecking yard with some good parts, fair used windshield and back glass, hand-brake lever, etc.
He also has the front half of a '58 3800, 8 lug SINGLE wheel type hubs.
Will these fit my '57 3600 spindle, brake shoes, and backing plates?
He wants $50.00 each, cheaper than having to hunt down a full set of dually rims, if they will work.
I think the 3800 really is a one-ton?
If that's correct I'm surprised to see it with the single wheel hubs.
Also need to know, is the rear small window glass flat, or not?
The wrecker has a couple of them, but they are scratched.
He claims they are not flat, and are unavailable new?
I'm going to USE this truck, so it will never be show quality, just decent.
First thing is to get it operable!
1957 Chevy 3600
not sure about the wheels, but the shop manual should indicate any differences in brakes and associated bits
he's right, the back small window is crowned and not reproduced, take what you can get
I just checked with 4 different parts suppliers, all 4 had listings for the small window glass, most even had 3 options, Clear, Green tint, and Smoke tint.
If you're planning to work this truck and drive it regularly, you might consider intalling this style back window. I have one in mine, and am very glad I did it. Especially in the summer.
Bill Burmeister
FIRST thing is to get the front wheels/hubs sorted out.
Then glass.
I've had those rear windows before, didn't like them as the latches seem to fail, they leaked water, etc.
I would also have to cut my cab for installation.
1957 Chevy 3600
That slider is a direct fit, no cutting required. It's designed to fit using the OE style gasket. I've had mine in for several years, the latch doesn't rattle and fits very tight, and I havent had the first leak. I've even had it in some nasty Illinois thunderstorms with no leakage.
Bill Burmeister
Boys, boys boys!
Thing sits on 235/75/R16's off my old K2500 1989 Chevy. Nothing changed, removed, or dismantled. No rubbing on wells or anything. Junkyard will have a full set of these, even if it takes 4 trucks to get um.
Chey
LOST1953
My favorite color is CHROME
The ugliest trucks are driven by the prettiest girls wink
I dont suffer from insanity, I enjoy it!
O Lord, WHY did I buy another "Thing"? (again??)
1953 Chevy 3800 1-ton Gallery
More photos at MSN
I'm off to the salvage yard in the morning.
Buying the single wheel hubs!
1957 Chevy 3600
Hurray!
My wheels will now sit INSIDE the fenders!
The drums I got with the hubs are better than my old ones too.
Now I just need to find a source for the #5756 oil seals.
Kragen wants $35.00 each, seems insane to me for a simple seal.
1957 Chevy 3600
NAPA = NOS20669 $17 ea .... 3600 or 3800
Moderated by  Dusty53
