4 members (klhansen, Bill Hanlon, 52Carl, farmallb), 341 guests, and 5 robots.
Topics128,159
Posts1,057,037
Members48,460
where can i get the shallower water pump pulley (53-54?) since i plan to press the flange back on the shaft of the original w/pump that came on my 60 235?
You should do a serach on this. There is an entry somewhere that talks about using a pulley from a Ford!!
1951 1 Ton Completed
Try an old time wrecking yard or a swap-meet. Take your old one for a guide.
That would be me who used a Ford pulley, and it fits perfectly and is the right diameter for the late 235. I think it was from a 300 Ford although it may have been a Y block, I don't remember. However, if you are planning to run a mechanical fan I would recommend doing the adapter plate and using the earlier water pump. Clearance with the short pump still isn't very good and the fan needs to be higher up on the radiator to be effective.
Paint & Body Shop moderator
