5 members (TexasJim50, tclederman, Gray_Ghost, greenie-reddy, baldeagle), 65 guests, and 8 robots.
Topics128,020
Posts1,055,345
Members48,419
#556978 07/19/2009 9:44 PM
can someone tell me how to wire the headlights? and include a the dash switch in the equation? I can run a wire direct to the battery and get them to work, so that wiring is complete, not sure how to get the switch to be in the middle of this. I also have a alternator w/ one wire, I dont think anything is running through the regualtor on the firewall, not sure, but dont think so. I am missing headand tail lights. have switches
56 stepside 3/4 ton longbed
have an assembly manual? has a handy pic in it and a lot of others re the wiring and where to route it - note as well that the switch itself has labeled terminals .... of course assuming you're using an actual harness with all the correct [universal] colors
with a one wire alt, you can take the regulator right off the wall
