| | | Forums66 Topics128,087 Posts1,056,377 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 3 New Guy | | New Guy Joined: Aug 2006 Posts: 3 | Looking but cannot find. Mine rusted through. Any suggestions or links? | | | | | Joined: Feb 2004 Posts: 29,826 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,826 | Do you mean the bimetal spring on the heat riser valve? I have substituted a coil from an automatic choke at times, but the performance isn't great. Be sure the heat riser shaft is able to turn freely, and the flapper valve isn't damaged or burned away. The spring should be wound in a direction that routes exhaust heat toward the intake when the engine is cold, and directs exhaust gas away from the intake after warm-up. Jerry
| | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Obsolete Chevy Parts Search for EXHAUST MANIFOLD THERMOSTAT SPRING 6 cyl Part No. 838573. Or, call them at (229) 686-5812. Hoyt | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
