6 members (Rusted Nut, Lightholder's Dad, Bill Hanlon, Hotrod Lincoln, Buckeye998, 1 invisible), 87 guests, and 3 robots.
Topics128,091
Posts1,056,393
Members48,442
Looking but cannot find. Mine rusted through. Any suggestions or links?
H Online: Content
Do you mean the bimetal spring on the heat riser valve? I have substituted a coil from an automatic choke at times, but the performance isn't great. Be sure the heat riser shaft is able to turn freely, and the flapper valve isn't damaged or burned away. The spring should be wound in a direction that routes exhaust heat toward the intake when the engine is cold, and directs exhaust gas away from the intake after warm-up.
Obsolete Chevy Parts
Search for EXHAUST MANIFOLD THERMOSTAT SPRING 6 cyl Part No. 838573. Or, call them at (229) 686-5812.
Hoyt
Classic Parts
ME188 Jim Carter
ME188 American Classic (somehow they use Jim Carter's part numbers)
