4 members (fonz8261, Otto Skorzeny, King Kielbasa, 1 invisible), 90 guests, and 4 robots.
Topics128,077
Posts1,056,015
Members48,433
#554983 07/12/2009 8:00 PM
I am planning on having sid strech my axle, but am not sue if I should go 3" or 4". It looks like I will only have about 3" maybe 4" of clearance from the bottom of the axle to the road with the 4" drop.
What do you guys think? I really want to go with the 4" but want to be safe at the same time. How do you guys like your 4" drop?
I used a 3" axle because 4" would've put me below the "scrub line". The scrub line is a straight line from the bottom of the rim of any of your 4 wheels to where any of the 3 remaining wheels touch the ground. (NSRA specs). You can get more than a 3" drop from a 3" axle by either removing leafs from the spring pack or going with mono-leafs. Wheel size obviously figures into this also, I'm using 15" wheels, with 16" wheels, the 4" axle probably would've been o.k.
I used a 4" from Sid in my pickup and also pulled 3 leaves out of the springs. It made for a total drop of about 5-1/2". Personally, I really like the way it looks, but I also like stuff low. If you look at Sid's website, the tech article on how to lower an AD truck is mine. As far as scrub line, if I had one flat on the front, I would be fine. If both front tires went, I would most likely be plowing pavement depending on the road. I suppose I am just planning on only one flat at a time. As far as clearance with both tires good, it is no worse than my daily driver late model pu. You just have to avoid big obstacles laying in the road...
i have one of sid's 3 inch front axles, with 1 leaf removed.
i also have 15 inch wheels with 225-70's, and if i get a flat i am gonna be in trouble, scrub line wise. not by much, but in trouble. the leaf removal has nothing to do with that.
i have 15 inch wheels with 225-70's.
you can look through my web album and see what it looks like.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
I have a 4" drop axle with 2 leafs removed. Using 16 inch wheels. Only problem is, I haven't installed it yet...I hope its not too low!
"Effective leadership is putting first things first. Effective management is discipline, carrying it out."
---Casey---
http://s676.photobucket.com/albums/vv127/davisears/?albumview=slideshow
Hell Casey, you can never go to low. If anything you can always plow the streets of Idaho with your truck.
JAWDY #556725 07/19/2009 12:14 AM
With 205 75/15 tires I could only use the 3 inch dropped axle on my 37,I also took some leaves out of the springs to drop it about 4 inches.
Thanks guys... I really want it low, my last truck, 68 C-10, I bagged. Without air it sat on the front crossmember. I guess it made me a little gun shy to drop it to low. I think I will go with the 3" and drop a couple leafs and modify the mount and straps to gain another inch or two.
Well, I have a question, with those of us that have a 4inch drop axle, what would be the proper thing to do so we wouldn't have to worry about plowing our local streets? Would having 16-17 inch rims help? What about the series of tire I.E 75 and up. And if all that's the case, wouldn't that defeat the purpose of a 4inch drop cause it seems to me that those factors would lift the truck up a smidgen and we should have gone with a 3inch drop after all. I'm just curious cause I to have a 4inch drop axle that I haven't installed and want know before hand what I should do. I want my 59 as low as I can possible go. If I'm going to be helping the road department out by plowing the streets every time I get a flat I'm not to sure about that.
JAWDY #556849 07/19/2009 12:12 PM
jawdy, thats the exact reason i went with a 3 inch axle, not wanting to "plow" the streets too much if i got a flat, or having to install bigger wheels either.
if i want it lower, i will remover more leafs.
lower looks so cool, and i eventually want to lower mine some more, but the ride quality will suffer.
leonard
Jawdy, I love your insight----
"Hell Casey, you can never go to low. If anything you can always plow the streets of Idaho with your truck."
I agree with your statement above. I'll be picking potatos from my drivers side window. A real "field truck".
---Casey---
