| | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 81 | I am wanting to plant a 350 in a 65 Chevy 4x4 and was told the original engine was a 283. Starting with the motor mounts... do I need to acquire the mounts off the 283 to put back on under the 350? or did will the mounts need to be from the truck the 350 is off of? I do know they are not set up the same with the positioning of where the mounts sit on the frame... so I am guessing it will have to be one or the other. Any assistance is greatly appreciated. thanks
Boogity, Boogity, Boogity Let's go racin boys. Drive fast, turn left. GO #20.
Real trucks where bowties.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You can use the 283 mounts just fine on the 350 block.
Bill Burmeister | | |
