| | | Forums66 Topics128,031 Posts1,055,435 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 43 Apprentice | | Apprentice Joined: Sep 2006 Posts: 43 | Hi Guys. purchased a new set of orgional guages for my 51. the temp guage is not the ether filled tube. it has 2 leads. can you please let me know what the resistance range is for that type of guage so i can go and get a sending unit www.cardomain.com/ride/3358353thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1951 Chevy Styline automobile
1951 gauge cluster sets with original-style temperature gauge and gas-filled capillary-tube sender are available for trucks. From whom did you get your automobile gauge cluster?
Was an electrical temperature sender used on the original 1951 automobile gauge? If the capillary-tube sender was also standard in the 1951 automobile, you need to get sender information from whomever you bought the gauge.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Capillary tube temp gauges were used through 1955 on US cars. I agree, you need to check with your gauge supplier.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2006 Posts: 43 Apprentice | | Apprentice Joined: Sep 2006 Posts: 43 | i bought this as a NOS item on Ebay.
any ideas would eb greatly appreciated
thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I'd try NAPA TS 6469, should work, might need an adapter to fit the engine fitting
Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Bill,
If chaimv has an original 1951 216 or 235, and that sender is the later 235/261 electrical sender, it is made for a larger hole in the head (1/2" x 14 NPT). If chaimv has the smaller hole, would there be an adapter available?
chaimv,
What year engine do you have in your car? If it is late early 55 or older, the hole will most likely be too small for that NAPA electrical temperature sender.
What is the eBay seller's username? It is hard to believe that the gauge set is NOS if it is for a 1951 car (unless the car engine used an electrical sender/gauge).
Tim
| | | | | Joined: Sep 2006 Posts: 43 Apprentice | | Apprentice Joined: Sep 2006 Posts: 43 | hi guys
thanks for your help. i have the origional 216 in the car.
the ebay seller is rohnaz. he did say multiple years. and he did not specify if it was for the car or not. other then the higher oil pressure gauge and electric water temp it looks identiacl to what is in my car now
i will see what NAPA has to say tomorrow | | |
