| | | Forums66 Topics128,080 Posts1,056,063 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2002 Posts: 48 | I am attempting a rear end swap on my 51 1/2 ton P/U I just got it out today and the upper shock mounting brackets on the frame look fine can I use these to install "modern shocks"? Should I be looking for spring perches for a 1953 to weld to my donner rear end or can I use more common newer spring perches. Where did you guys get your perches? (If you can't tell I am trying to find a cheaper alternative to the $140 rear end upgrade kit that chevyduty offers.) Thanks for any info in advance, I couldn't be doing all this with out all of your advise. Zach
If you need a tool and don't buy it, you will find you have paid for it and don't have it.
#5542 11/26/2002 10:49 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You already have modern shock mounts on your truck, if it's a 50 or newer. You can order shocks with either the 'eye' type end or the 'stud' type end. All you have to do is a bit of searchin in the catalog. I use Gabriels on my truck, they have a bayonet on one end and an eye on the other. They work great.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Nov 2002 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2002 Posts: 48 | I went to Speedway motors tonight here in Lincoln NE and talked to a counter guy who ownes a 51 5 Window and has done this upgrade. All I needed was comon 3" spring perches they were only $12.49!!! A far cry from $140 They also had a inclonometer for $10 to set the pinion angle, for those of you that don't know you want the pinion angle to be the same as the angle of the tranny output shaft. Zach
