3 members (Nick in Manitou, TooMany2count, klhansen), 120 guests, and 4 robots.
Topics128,109
Posts1,056,240
Members48,437
How many teeth on a 6 verses 12 volt fly wheel. While trying to start my 41 chevy thats been setting for 35 years the motor kicked back and broke the bendix and the snout off my starter. In all my years of messing with the old chevys I've never had this happen what did I do wrong. I'm pretty sure I had the correct starter to flywheel combo.
I think the 6V is 139 tooth and the 12V is 168tooth.
ttodd,
I have had several "snouts" break off on starters, but it was always a issue with the starter drive gear and its little retention collar.
After sitting for that length of time, the possibilities of what caused this problem would be endless.
Your post doesn't indicate exactly what vehicle you are referring to..a '41 stock truck!
Stuart
Thanks for the replys. It's on a 1941 schoolbus or whats left of it. I got the old guy running Sunday afternoon after changing the flywheel to a later model 12 volt wheel. Will the snout from a 12 volt starter swap with the 6. By the way the old boy ran realy good after the 35 year rest.
