| | | Forums66 Topics128,080 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#55403 01/22/2006 4:47 AM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | How many teeth on a 6 verses 12 volt fly wheel. While trying to start my 41 chevy thats been setting for 35 years the motor kicked back and broke the bendix and the snout off my starter. In all my years of messing with the old chevys I've never had this happen what did I do wrong. I'm pretty sure I had the correct starter to flywheel combo. | | |
#55404 01/22/2006 6:46 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I think the 6V is 139 tooth and the 12V is 168tooth. | | |
#55405 01/22/2006 8:16 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | ttodd,
I have had several "snouts" break off on starters, but it was always a issue with the starter drive gear and its little retention collar.
After sitting for that length of time, the possibilities of what caused this problem would be endless.
Your post doesn't indicate exactly what vehicle you are referring to..a '41 stock truck!
Stuart | | |
#55406 01/25/2006 1:00 AM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Thanks for the replys. It's on a 1941 schoolbus or whats left of it. I got the old guy running Sunday afternoon after changing the flywheel to a later model 12 volt wheel. Will the snout from a 12 volt starter swap with the 6. By the way the old boy ran realy good after the 35 year rest. | | |
