8 members (cmayna, Wally / Montana, Shade Baby, Goach2, Donf, dt235sd, Otto Skorzeny, Joe H),
60
0
Mod | | | Forums66 Topics128,118 Posts1,056,307 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | OK guys the truck is getting closer to being able to drive.
When I bought it the PO said the ignition switch was missing & had been hot wired.
I imagined cut & boogered wiring underneath but to my surprise I found the harness was untouched & a paperclip was used to jump the ignition.
I know you can find new switches on eBay for about $50 & the new lock tumbler for another $50.
I however don't want to spend $100 for this.
I would be perfectly satisfied with a toggle for the accessories and ignition since the starter is on the floor.
Anyone ever do this? What would be involved? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Less than $20 for a non-original-style replacement. You might want to put your truck brand/year/model information in your Profile. It will help people know what truck you are referring to. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Great - just ordered a new generic switch - Now - in order to wire it up correctly - looking at the original plug in my truck - what are the 4 slots?
What I mean to ask is - which slot is the "hot" which is the accessory which is the ground etc?
that way when the new switch arrives I can create a pig tail to plug into the original harness & get it right the first time. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | still haven't said what year, there are variations and there aren't any mind readers here  Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Wiring diagram , '55, '58 is similar. BTW, $50 isn't too bad for a correct original style switch, but the lock cylindr shouldn't run any more than about $12, as priced from American Classic.
Bill Burmeister | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | sorry about the year - I always assume you guys all know me.
58 chevy apachie 3200 - stock 235 with the foot starter.
No fuse box at all & a heater, though the heater looks stock - the switch to turn in on does not in any way look stock, but that's another post.
I bought the truck several months ago & it has been in storage for 15 years. It is a Arkansas truck so there is very little rust - only the cab corners. For Illinois that is a big deal. I'm in the process of getting it started - new carb on the way - all the fuel system is new.
I need to rebuild the brake master cylinder & fix the ignition & it should be roadable. I've had it move under its own power in the driveway - but the old carb is junk & there are no brakes.
So this weekend I will fix the brakes - expect the new carb end of next week & the switch is all that is needed to be on the road.
Cant wait! | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Longbox 55 - where are you at in Danville? My Dad is selling his farmhouse in Danville - out Perrysville road. I grew up there - went to Westville H.S. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | w/ a foot stomp starter all you need is a simple two position switch. so to check out your new switch use a VOM. connect it to a lug using the ohms scale. when the needle or gauge reads ZERO, that's a dead short, meaning that you have continuity between the two wire clips. now connect the other wire to another lug. turn the switch to the ''on'' position. move the two wires about and figure out which two are connected w/ the switch in 'on' position. mark then on the switch as battery & on. better yet, draw the back of your switch on a piece of binder paper, once you have figured out since you have a 4 position switch, draw up which post is BATT - IGN. / ACC. / START. the battery lug should never to electrically connected to any other post/screw when the key is removed. http://www.ehow.com/how_2076998_use-voltohm-meter-safely.html
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | sorry about the year - I always assume you guys all know me. This site has over 20,000 members. I suppose you know what kind of truck each one of them has. | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | My first guess would be chevy - but I guess there could be a couple of Toyota guys here trying to figure out how to make theirs better. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Your first guess would be chevy? Chevy what? 1953 with a 216? 1956 with a V8? It's hard for us to remember the details and nice for you to get replies specifically related to your truck/drivetrain.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | My first guess would be chevy - but I guess there could be a couple of Toyota guys here trying to figure out how to make theirs better. and quite a few GMC guys, not necessarily the same as Chevy OR Toyota in any detail why not put it in your profile, so folks can always have a way to figure it out  Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Bill,
You asked the most pertinent question - why not put it in your profile?
This is off-topic : I've seen people post a question and not receive any answers because they had nothing in their profiles and their question did not say what truck they were asking about. Then, they post impatient "no answers?" or "anyone out there?" when no one replies. The answer is that most people who have answers would rapidly answer (nobody seems to be bashful in this forum), if the question were more clear about make, year, model.
Tim
| | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | I didn't mean to start a fight! - I received my shinny new ignition switch today. Thanks for all the help.
By the way - I'll update the profile. | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Since we're on this topic,
When my '49 chevy 216 is converted to 12V ,do I need a different igniton switch ?
Just-a-hacker
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Thanks, oh goody ,one less thing to buy !!! | | |
