8 members (Gdads51, Otto Skorzeny, moparguy, Greg_H, Bill Hanlon, Shade Baby, DaveV, 1 invisible), 102 guests, and 2 robots.
Topics128,266
Posts1,058,318
Members48,485
#535658 05/07/2009 4:47 PM
U
U Offline
Does anyone know where to get all the different sized clutch head bolts from? I am trying to find the small ones that run along the vent inlet just below the windshield and behind the hood. There are 5 small clutch heads there. Thank you.
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
UnklRod #535670 05/07/2009 5:24 PM
Drew
DrewP #535672 05/07/2009 5:28 PM
Clutch-head bolts from Totally Stainless and/or McMaster-Carr?
All of these vendors have carried one or more sizes/styles of clutch-head bolts/screws (over the past 10 years).
http://www.restorationspecialties.com/ (they had several styles/sizes)
Jim Carter
Classic Parts of America
LMC or Brothers
tclederman #535706 05/07/2009 7:50 PM
And those are about the only places you'll find them.
~Jim
U
U Offline
Hey all,
Just called Totally Stainless and McMaster-Carr. Both told me they do not carry the Clutch Head bolts.
Jon
More pix
UnklRod #553751 07/08/2009 2:20 PM
That is correct (and is what BIG CHEVY 3600 was saying). The four companies that I posted above used to sell clutch head bolts/screws. A few other might sell some now (like rear fender/box bolts from Classic Parts of America), but new clutch head bolts/screws are not commonly available (and certainly not available in all original sizes).
http://www.jdheritage.net/DeerelyDeparted/Items/7001.asp
http://www.chevsofthe40s.com/detail/10860.html
http://www.classictruck.com/product...erior_Screws_and_Sets_Clutch_Head_Screws
tclederman #553757 07/08/2009 2:36 PM
Mr G's carries some.
http://www.mrgusa.com/
Bob
UnklRod #553763 07/08/2009 2:47 PM
Originally Posted by UnklRod
Hey all,
Jon
Yes,as I recently found out myself. Sorry I misled you. You might consider button head screws which look slightly similar, unless of course you are trying for a correct restoration.
Drew
DrewP #553936 07/09/2009 1:53 AM
I use button head bolts
~Jim
U
U Offline
Yes, I am trying to restore the truck with original clutch heads. I am trying to educate myself on where they all went. Were they used on the steering column rubber flange and tranny cover?
I placed an order with Filling Station for the following sizes:
CLUTCH-HEAD 8-32X1/2
MACHINE SCREW 1/4-20 X 3/4
10 X 1/2" CLUTCH HEAD METAL SCREW-ZINC
5/16-24 X 1 1/4 CLUTCH HEAD FLAT.
I really would like to know what size I need for the fresh air vent cowl that mounts on the cab just below the windshield and behind the hood.
I looked in the Chevy shop and assembly manuals and they really dont tell much of where all the bolts are located through out the truck. Am I missing something?
Thank you all for the help and patience with me!
More pix
UnklRod #554019 07/09/2009 7:01 AM
on a 57 clutch heads were used on the 2 screws in the door that hold the bottom of the division bar [round head], the trans floor cover [flathead countersunk] and the stepside fenders [round head] ... all others are phillips, including the cowl vent cover, inner air vents and seal at rear of hood on cowl, shifter on column, dash trim strip inside windshield, glovebox - steering column clamp is bolts
the asembly manual should show exactly where, how many, and size of every nut and bolt, may not indicate if clutch or phillips
Flxible #554038 07/09/2009 12:45 PM
U
U Offline
Thank you Bill,
I will take a closer look today....
Jon
More pix
