0 members (),
85
0
Mod | | | Forums66 Topics128,115 Posts1,056,291 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#55372 01/21/2006 10:00 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | I am rebuilding my SM420 4-spd transmission and I picked up a rebuild kit from Novak and have a question about which gasket to use on the input shaft cover. The Novak kit gave me two gaskets for this purpose a thick one and a thin one. The directions do not say which one to use. As luck would have it, I can find all the gaskets I removed but this one, so I can not compare to what was there originally. Any help with this would be greatly appreciated. Thanks.
Jim
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
#55373 01/21/2006 10:12 PM | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | I would call Novak, I've heard they have really good customer support. Maybe someone else in here has the answer for ya, but I'd definitely give them a buzz. --- http://www.novak-adapt.com/contact/contact.htm Tech: 435.753.2513 - 9a to 5p MST - --- [email protected]This is express support available only to our existing customers who may require assistance with a previous purchase --- -W | | |
#55374 01/21/2006 10:22 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | I tried calling the Novak Tech support line, but no answer. I did write them an email, but who knows how long before they answer. Anyone else run into this problem before? Thanks.
Jim
#55375 01/22/2006 4:57 AM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Novak Tech support got back to me and gave me the 411 on the different thickness gasket question. The oil seal tends to wear a groove in the input shaft after years of service, so by using the thicker gasket or maybe both you move the oil seal to an unworn area of the input shaft.
