4 members (FAST55, Bill Hanlon, Nick in Manitou, 50Chevy3100), 97 guests, and 2 robots.
Topics128,138
Posts1,056,751
Members48,454
sly
Offline
I purchased an original flatbed from a 3/4 ton to put on my 1/2 short w/b 51. The 1/2 ton frames taper out at the rear. However, 3/4 tons had straight rails and I'm sure I will need to shorten it to make it look proportionally correct
Is there a good way to mount this bed on my truck so that it will look right?
No. You'd have to cut it down and fab up some rails to match it to your 1/2-tonner's wider frame. Otherwise, you'll be lengthening the wheelbase on your truck to match the deck. Sound like a nuisance to you?
1951 3800
-hotshoe
sly
Offline
The frame rails start out at 39" apart behind the cab and end up at 46" at the end. So I think I can fab some 46" cross members to attach to the bed's cross members. As for the length, I dont think it will be too much of a nuisance to have it shortened.
My other concern are the boards that run along the top of the rails to mount the bed on. As I mentioned the rails are 46" apart at the end, but they reach 46" just behind the rear axle. So there is about 18" where the rails are the same distance apart, but the portion of rails behind the cab to the back of the rear axle are tapering out. This creates an angle along the top of each rail that seems to prevent mounting a solid wood beam down the length of each rail. Any ideas?
Thanks very much for your help.
Sounds like a 3/4 ton frame would just about bolt under that flat bed, and would probably look the cleanest of your choices?
Grigg
1 Offline
Get out the tape measure, saws and grinder.....anything is possible if you have the drive to do it.
Go for it and take pics.....
sly
Offline
I think I'm going to fab new cross members, move the the back one in so that it sits on top of the frame rails and then shorten the bed to look right on the short wheel base. If I get real frustrated I will throw the box and fenders back on it.
By the way, it was a clean 50 3/4 ton flat bed that got me headed this way in the first place. Matter of fact I almost bought it. He wanted $3500.00. If he would have taken $2500.00 I would have.
Thanks for the help guys.
