2 members (klhansen, Peggy M), 167 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#553663 07/08/2009 4:14 AM
Is it possible to run a 700r4 behind a stock 250 six? Are there any major drawbacks?
SixPac #553687 07/08/2009 5:35 AM
it's possible
don't know
Jim & Caroline
SixPac #553688 07/08/2009 5:37 AM
The major drawback is the 700R4 itself. It's very prone to overheating the overdrive clutch and eating itself. I inspected one today that was nothing but scrap metal.
http://www.chuckthetruck.com/page26.html
30,000 miles on it now and never a speck of trouble. I regularly 21mpg in summer (18-19 winter).
The TH700R4 has a bad reputation from guys who have tried to race it, or run it behind a powerful engine. I do have an 84 Caprice with 240,000 miles on it, the TH700R4 is stock and original and runs just fine... Behind s stock 250, it should live for ever, at least!
My 57 Suburban has a 250ci with a TH350 and the TH700R4 is a direct replacement for a TH350. The driveshaft will need to be shortened and you will need a way to lock the converter, available aftermarket, I do not remember who right now...
Check for clearance and don't forget to mount the TV cable properly!
Pretty easy overall!
'57 Chevy Suburban; '70 Chevy Impala.
I would find a 200R4 and run that, better gear ratios than the 700R4, and many were behind the 250 right from the factory.
