5 members (IHPWR, Peggy M, 55shaker, 1955 1 Series, 1 invisible), 78 guests, and 1 robot.
Topics128,211
Posts1,057,468
Members48,471
I want to move the gas tank for my '51 Chevy truck to the rear of the truck under the bed. Does anyone have any suggestions as to what used gas tanks from later model trucks/cars have been used in resto-mods before? I have left my frame completely stock and really don't want to hack it up at this point to get a new alum or steel tank to fit. Thanks in advance!!!
Check the "links" section at the top of this page. There are vendors that sell them.
Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
Jim & Caroline
I put a jeep cherokee fuel tank in my Dad's '49 3/4 ton. I un-bolted the original mounting straps and was able to use them to mount the tank from underneat the frame - using the tank seam (where the two halves were welded together from the factory) - as a flange against the frame. We had to trim about 1/8" off of the insides of the frame rails but it fit really well. Used a filler cap from a boat supply shop and mounted that inside the bed. Hope this helps!
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
Hi , Carolines where did You pick up the tank I would like to do the same thing on My 52- 3100 already took the tank out of the cab.
Pete
Quote
that's just a very basic start to get it to what you see in the photos on my wifes truck .............................
do a search for my name and read the gas tank pages. i have lots of info i have discussed already............. lots
tanks inc.
http://www.tanksinc.com/index.cfm/p...ry_id=69/home_id=59/mode=prod/prd128.htm
comes e/w antiroll shut-off vent.
used stock filler neck welded w/ 2'' pipe.
gas line 2'' connects the tank to the filler.
cut the new tank to fit the truck :: cut the old truck to fit the tank:: headscratch
cut off the as received new tank filler neck & seal/weld that hole off.
locate a new 2'' filler stub for the new tank for inlet AFTER cutting and measuring where to cut a hole in the bed wall.
make a mock-up using the old filler neck to a new steel sheet that attaches to the outside bed wall.
measure and cut U shape to clear emergency brake cross bar AFTER cutting truck frame triangle plate. which means you should probably remove the bed completely. mark where you might weld the tank tabs first.
cut the stock frame corner brace out so the tank can fit up against the bed's bottom cross struts/bars.
i used the bed cross metal bed struts as an anchor point to weld 4 [pre-drill for 1/2'' rod] 1.5-2''x 1.5'' straps to hold the tank up high.
the tank is held up w/ four rods. double nutted at the top and single at the bottom. two cross metal straps 2'' x3/16'' hold the tank up from the bottom. all has dense rubber padding glued w/ E6000 glue top and bottom where ever the tank touches the metal bed struts and bottom cross braces.
weld on a plate to the cab side where the old filler WAS.
NOTE::
we moved the axle when fitting the new 1977 , 3.40:1 chevy burb 4x4 rearend back by 2.5-3.0''
it centers in the wheel well far better than the 1.5'' offset sold by vendors.
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=0035595-R1-014-5A.jpg
see all my photos........... towards the bottom.
good luck cool
it's worth the long hours of work. wave
WHY
i have a very simple crank down cable
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=24-1.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=23-1.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=20-1.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=2748800-R1-E026.jpg
to operate the rear spare tire and DON'T HAVE to groval in the wet/snow/mud/rain/dirt 10 days or 10 years from now to lower the spare tire when she gets a flat && she can also. Which is where MOST put their after-market gas tank.
THAT's what makes all this work
IT's a whole game plan when you think about what it is, when one does work to a truck that we'll keep forever .... YOUNG
Jim & Caroline
Thanks good friends for the feedback!!! Appreciate it!! If you're ever in Kentucky... I'll fix you up some barbecue like you've never tasted before!!
