1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | my drivers window doesnt move up or down. I totally removed the regulator and the gear seems ok and moved when the handle is cranked, but it doesnt manipulate the window. my gear piece has a approx. 4" piece of steel on it that appears to have the un-connected end broken. the piece looks kind of like the window tabs would roll through it but they are to small to not fall out of the channel of this piece. all photos I have found show the other side of the regulator, so I cant see what this piece does. does this piece attach some how to the window to make it go up and down? I have the bottom channel of the window screwed into its channel so it os connected and the small piece towards the door lock edge is there and one end of the window scissors fits in ot ok. this small broken piece somehow has something to do here but.....
56 stepside 3/4 ton longbed
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | need some pictures, sounds messy see here, there's 2 arms that have 'pegs' that slot into the channel attached to the bottom of the glass [the sash], the 3rd arm goes into a short piece of the same kind of channel that's attached inside the door, that gives the leverage for the other arms to move the glass Bill | | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | I have the 2 arms into the bottom of the window long sash. I have the 3rd arm attached ot a small channel welded to the inside of the door. where does the 4th arm go? the gear piece on the regualtor on mine has a approx. 5" long piece of metal on it hinged w/ a stud. it can move clockwise or counter clockwise. is this where the 4th arm goes? when my window is attached to the regualtor, and the sash isd screwed in, and the 3rd arm is in the door channel, ym window still does not go up or down. I think the key is the 4th arm??
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 4th arm? - the 4th arm is the other end of the 1st, sounds like yours broke right at the pivot point? see this picBill | | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | if your photo was flipped over, on mine the "fourth" arm or bar I am talking about is on the gear and held in place w/ a stud
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | OK - here's the other side, I think the piece you mean is the one that's riveted from the bottom of the big arm to the cam/gear, that's the "driving link" .... can be just seen in the vendor pic, looks a different color at the bottom edge ... the ends of the rivets are swedged, one musta come loose, might be able to repair it Bill | | |
