0 members (),
125
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 56 | Couple questions here:
1) About to replace a bunch of things on my '53 one ton I just purchased w/ a '56 235 engine. I found a box of AC Delco Platinum spark plugs in my garage (model 41-932). Why I have them I don't know but will they work on my 235 engine?
2) My friend is going to help with installing all of my new parts (oil, fuel, water pumps etc.) I already bought an alternator and bracket. He thinks I should wait and get it running before I convert to the 12 volt. I don't see the point in waiting if I already have most of the items needed for the conversion. What's everybody's opinion?
3) Also, I have the original oil bath filter but don't like the idea of adding oil and cleaning. I did some research and believe I can keep the original set up but can rig a modern day paper filter in it to make it more up to date. Is this true and are their any negatives to doing this?
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The plugs will not work. They are for late model applications, and have the wrong type of sealing surface to work with the 235 head. As far as getting it running, it would be worthwile to to get it running before you start changing things, if only to make sure there aren't going to be other problems. Which style oil bath do you have? There were a few different styles. The base model version, which simply has an oil wetted copper gauze as the filter media, can be easily converted by taking the od and id of the filter along woth the hight of the element and matching it up. Same applies to the larger styles, but you may have to do some trimming to make a paper element fit.
Bill Burmeister | | | | | Joined: Feb 2009 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 56 | No idea where the speedo came from, I'm going to try to find an original one to replace at some point. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | A '56 235 would be a 12V system engine, so are you talking about converting the chassis and instruements ?
Drew
