7 members (MickeyP, David Bush, kades51, Gdads51, cmayna, Donf, 3800GUY),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,702 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 134 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 134 | do all 41 gmc truck use the same gear box. I have 1-1/2 ton and the gear box leaks oil like a harley. thanks kat
I like fixing stuff.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the question should be 'do all old GM steering boxes leak like harleys', the answer would be yes  need to regasket it and use a stickier oil [JD corn head grease works] in it Bill | | | | | Joined: Feb 2000 Posts: 5,201 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,201 | I believe the gear box is the same, but the steering shaft coming out of it will be longer for the heavier trucks.
Get or make a few new gaskets and get a seal for the sector shaft from any local auto parts house. GM used the same seal for a bunch of years. Add some thin grease and you are good to go.
Do a search for steering box grease or oil or lube, you will get a bunch of information.
Joe | | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | I had a 68 Chevy 4x4 and the cardon joints leaked along with the steering gear box I put in some TRACK ROLLER LUBE this is a oily greasy mix and it stopped my problems of seepage. I picked up this stuff at a tractor equipment shop 62 Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | While you have the box out go ahead and replace the bushings for the sector shaft, this will make the new seal last longer and tighten up the box too. The bushings are cheap and easy to do. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I got a 79 Harly and the old saying is if she aint leakin she aint runnin , so there .
Pete | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | "Old Chevy Trucks do not leak oil, they mark their territory!" As far as the boxes themselves go, according to the manual, they are the same. But most likely, all you need are new gaskets and seals. Also, try a heavier lube, such as Cornhead from John Deere, or the track roller lube mentioned, which is most likely the same type of lube.
Bill Burmeister | | | | | Joined: May 2009 Posts: 134 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 134 | thanks guys for the help. this old girl is new to me. she road 100 miles in 30 years. and I put 400 miles in less than a month. she's bound to cry a bit.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I had mine rebuilt professionally and it is filled with 80W gear lube. It doesn't leak at all. A seal will not hold fluid if the bushings are worn and worn bushing also cause some steering slop. | | | | | Joined: Apr 2006 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 62 | This may be a little off topic, but which part in the steering box would wear the most, the shaft & worm or the shaft & sector? I have "bump steering" and can get a NOS shaft & worm, but can't seem to find the sector shaft. Any help would be appreciated. I have a 1939 Chev Suburban. Thanks, Stan Norrish | | | | | Joined: Feb 2000 Posts: 5,201 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,201 | You would need to pull it apart to see for sure. The shaft has roller balls that run in a groove inside a cage, the cage is what runs on the sector. Any one of the three can be bad or none of them, it depends on how it was maintained.
The sector bushings are the main wear items as they take the most load. The lower bearing on the worm shaft is also a wear item, its outer race is part of the adjusting nut on the bottom so check it close.
Joe
| | | | | Joined: Apr 2006 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 62 | Sorry Joe, but 1939 was the last year for the solid sector shaft. It does not have the recirculating balls--that began in 1940. Thanks for the quick reply. Stan | | | | | Joined: Feb 2000 Posts: 5,201 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,201 | You are right, I missed that in the post, guess I didn't read it fully.
On the '39 the shaft and worm are one piece, no wear there except on the ends of the worm were the bearings ride.
The sector most likely has the most wear in the teeth since its stationary, the worm is always rotating which spreads the wear out among the teeth.
The 1 1/8" bushing on the sector is probably worn also. You can add a second bushing out at the end of the housing in place of the spacer for more support of the sector.
A good cleaning and adjustment does wonders for the old boxes. Even if its worn, the most you will have is a little extra play in the wheel at the straight ahead position.
Joe | | | | | Joined: Apr 2006 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 62 | Thanks, Joe. If I read this right, perhaps all I need to do is clean and replace all bushings and bearings. I have a significant play as it is and want to correct as much of it as I can. Thanks again, Stan | | | | | Joined: Jan 2000 Posts: 101 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 101 | I have a 45 1 1/2 ton that is stock but has a lot of slop in the steering. Where do I start to fix/take out slop?
1946 1/2 ton - 1962 "261" 1953 1/2 ton 5-window - "235" 1955 1/2 ton - 55 "265" Corvette motor 1959 1/2 ton Fleetside - "283"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Is there any way to copy that to a personal computer?
dg
Denny G Sandwich, IL
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Bottom right corner after you expand a picture; look for the download symbol. Looks to be one at a time for a download just like Brad Allen probably had to load them. Wrench Fetcher, PhD | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah, done that many times, but I'm lookin' for the easy way out. Guess some things in life just taint easy.
dg
