1 members (Gray_Ghost),
79
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | I needed a way to attach flags to my 55.1 PU for an upcoming parade. I came up with something I think is pretty trick. I thought I'd share this in the event someone else could make use of it. Pic1 Pic2 I modified a rubber block style stake pocket anchor. I took out the eye bolt and replaced it with some 3/8 all-thread. I threaded the inside of a short length of 1/4" water pipe. I screwed this onto the threads sticking out of the top of the anchor. The flag stick fits loosely into the other end of the pipe. regards, Leon | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 |
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Clever. Have a great 4th of July.
Drew
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Did you forget your camera?
~Jim
