7 members (1955 1 Series, cmayna, Gray_Ghost, JW51, Pete1946, 55shaker, 1 invisible), 157 guests, and 2 robots.
Topics128,070
Posts1,055,900
Members48,429
#552698 07/05/2009 12:13 AM
I have a stock 1949 3100 1/2 ton with a 216 engine, and would like to convert it to a more efficient transmission. I am looking for a 4 or 5 speed with a higher ratio than the stock 1:1. Any ideas on what can be easily attached to the stock bell housing. I realize I will probably have to replace the rear end, so I would also like suggestions on what could be used with the stock 6 lug 16" rims.
There are several tech articles on this swap in the Tech Tips link.
Drew
There are several ways to accomplish your goal, but there is no quick, easy, or inexpensive way.
You may be able to get the desired results by changing the rear ring and pinion gears to a 3.55 ratio. Jim Carter has them.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
