6 members (52Carl, Otto Skorzeny, cmayna, Gdads51, Wayne67vert, SmalltownTRKGuy), 125 guests, and 0 robots.
Topics128,050
Posts1,055,632
#552389 07/03/2009 8:14 PM
I
I Offline
New to the place and first resto project. Young and have always loved classic trucks. but i have a problem. i have a 1953 gmc 3/4 ton (will be adding pics soon) and i cant seem to get the headlights to work. everything seems to be wired correctly. the tail lights and the dome light work but not the headlights and dash. any suggestion PLEASE. i am guessing maybe the switch is bad, but wont find out till i recieve it in the mail.
1953 GMC 3/4-Ton
In Photobucket
In the wind, til the end
Drop the switch out of the dash so you can get to the wires, and use a jumper lead to bypass the headlight circuit. If the headlights still won't come on, the problem is probably at the dimmer switch. That's a pretty common failure on floor-mounted dimmers because they are in a pretty hostile environment under the floorboard.
I
I Offline
thanks for the advice
1953 GMC 3/4-Ton
In Photobucket
I agree with Jerry, most all of my problems with the lights are in the floor dimmer switch.....
Redryder pix
My Hotrod
