| | | Forums66 Topics128,094 Posts1,056,051 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#55221 01/18/2006 8:16 PM | Joined: Dec 2005 Posts: 7 Junior Member | | Junior Member Joined: Dec 2005 Posts: 7 | Well, Dang-o, I roasted my pinion gear on my '62 C-10 2wd. Bad, it can sit in gear with the motor running and not move. Does anyone have a bead on where I can get my hands on a ring and pinion plus install kit at an affordable price?  | | |
#55222 01/18/2006 9:12 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Do you have the original drop out diff. If so 1955-62 PU will interchange. Is it a stick or auto trans?
See the USA in your vintage Chevrolet! My Blog | | |
#55223 01/18/2006 9:26 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | ras4jeep,
Not to question your post, but is what you say possible. What did the rig sound like moments before it wouldn't move anymore.
I could see maybe a broken axle. A ring and pinion catastrophe would have given you tons of clues way before it would have caused the rig not to move, and loud clues at that.
Stuart | | |
#55224 01/18/2006 9:32 PM | Joined: Dec 2005 Posts: 7 Junior Member | | Junior Member Joined: Dec 2005 Posts: 7 | Well it did give me some clues. On average I commute 40 miles 1 way to work. That particular morn, she decided to be loud and grinding the whole way in, Normally I would have parked and towed her home, but I cannot be late for work, being in the military. I managed to make it most of the way to a friends house before she quit. ans I have already opened up the rear end. Ewww nasty looking. Pile of shredded steel at the bottom. | | |
#55225 01/18/2006 9:33 PM | Joined: Dec 2005 Posts: 7 Junior Member | | Junior Member Joined: Dec 2005 Posts: 7 | Yeah she has the original drop out front with a manual tranny | | |
#55226 01/18/2006 9:41 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | ras4jeep,
Now I know! Thanks...I was late for a mid watch when I was in the navy. Thirty days restriction to base...what a [censored]!
Stuart | | |
#55227 01/18/2006 10:45 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | For a replacement, try Tom Meyer in Miami, OK. His number should be in the archives, accessible through search.
Edited due to a major brain cramp on my part. | | |
#55228 01/18/2006 11:58 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | A center section from a 55-62 will fit. Post an add in parts wanted. Someone close by probably has one. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#55229 01/19/2006 12:16 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If you can't find one near you I can help.
GMCpanel,3/4-1 ton will not fit a 1/2 ton
#55230 01/19/2006 7:56 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | D'oh! Sorry about that - when I see an Eaton rear end question, I automatically think of the H05x/7x axles...my bad...  | | |
#55231 01/19/2006 5:45 PM | Joined: Dec 2005 Posts: 7 Junior Member | | Junior Member Joined: Dec 2005 Posts: 7 | Yeah i am in the navy up here as well. See what I can dig up. Push come to shove, I will call Border Parts down in San Diego, He has alway's had what I need at an affordable price. | | |
