8 members (Mike B, WICruiser, Youngin' Tut 59, Pete1946, Bizaircon, klhansen, LuckyLee, 1 invisible),
72
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,140 Posts1,056,770 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 95 | Which company has the repro 1 pc back glass rubber for barn doors pr.
Sully
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Jim Carter has a set of one-piece panel body rear-door glass seals; however, while it is a one piece seal it is not a continuous seal.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | might call Steele rubber, if it's available they make it Bill | | | | | Joined: Feb 2009 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 95 | All, Someone told me a company make the continuous one. Vulcanized anyway? I have most of the catalogs but none says one peice. Most sell by LFT,cut to fit?
Sully
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Steele lists them "vulcanized", which means one piece, they're THE source for GM restoration rubber goods, all made correctly of good quality material
Bill | | | | | Joined: Feb 2009 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 95 | Thanks I'll give them a look.
Sully
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | VULCANIZED has 1 sense: 1. (used of rubber) treated by a chemical or physical process to improve its properties (hardness and strength and odor and elasticity) Vulcanization | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | STEELE TYPE IN CHEVROLET AND GMC TRUCKS, INCLUDE YEAR AND TYPE. IT'S TOWARDS THE BOTTOM OF THE PAGE. Panels & Suburbans with back doors. 60-0380-81
$83.30/pr. BARN DOORSSmall center window - 90" long. 60-0082-83 $44.20/set Suburban upper liftgate. 60-0609-81
$75.90/ea. CLAMSHELL LIFT GATE | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | all weatherstrips not 'sponge rubber' would be vulcanized in that one sense Tim, note in the Steele catalog that the only parts specifically stated to be 'vulcanized' are window seals that are one closed loop, not the open-ended ones - their use of the term indicates the ends of the seal have been "heat set" [not glued] together [the 'physical process'] .... as they stated when I discussed the original barn door weatherstrips I supplied for them to repro - the "loop" isn't cast in one piece, it's extruded, then made into the correct closed shape, in the case of the TF door rubbers, the joints are at the square corners - the 2nd door only has the seal on 3 sides I see 'vulcanization' actually has a: "2. The cross linkage of an adhesive substance obtained by the application of heat and catalysts" Bill
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | As in: RTV......R-oom T-emperature V-ulcanizing (bonding) Vulcanizing usually means bonding in the rubber engineering world. FYI my TF barn window rubber came in a length which needed cutting and such. I wrote a how-to somewhere on the bolt recently on this procedure for non-vulcanized. However it has not been endorsed by anyone yet. Check my posts if you care. I actually think that non-vulcanized could result in a better fit due to the tolerances. I assume that Steele is selling the AD as vulcanized, meaning one continuous piece and not some other meaning. Bartamos.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | While it would be nice to know if Steele Rubber is referring to the curing of the rubber itself or to the bonding of a joint in the rubber (or, to both), the important issue with respect to the original question is: is the Steele part one, continuous piece - their description (and their use of the word "vulcanized") does not suffice as an answer to that question.
When I bought my 1954 Suburban in 1971, it had what I assumed were the original rear-glass pieces, and they were not continuous pieces of rubber. However, I would prefer a continuous piece of rubber (whether or not it is "correct") and I would trust Steele to make a seal that would last quite well.
Maybe someone will call Steele and get a confirmation about their part being one, continuous piece. Sorry, Bill, I assume nothing, especially at the risk of the cost of a Steele product.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no problem Tim, as I first said above, a call will provide an answer .... but I go by the 2 groupings [with pictures] in their paper catalog: "vulcanized back window gasket" [showing a one piece loop seal] and "back window weatherstrip" [specific length pieces showing profile] .... also note they provide a revulcanizing service for putting new rubber on motor mount metal brackets  Bill | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Thanks, Bill. I have reached the point that my cheapness will get put aside when it comes to rubber parts. I'll pay the Steele premium and not think twice about it.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 |  me too - if I'm doing an order anywhere and want some rubber too I always ask first if it's a Steele product or other, if it's not or they can't say I don't order there .... many of the usual suppliers carry the Steele line, and some are a bit cheaper than Steele direct who only sell retail at "MSRP" to give vendors a break Bill | | | | | Joined: Feb 2009 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 95 | Ok already. You guys are sounding like mad scientists. My 8th grade education and the love of hot rods just makes me want to do it right the first time and the one pc rubber just looks better,just couldn't remember the company that makes them. But, the cost $$ for a pair can be weighed vs the cut-glue-fit-glue-leak may prevail if counting pennys.
Sully
