6 members (Steelonsteel, dt235sd, Mike Burns, Youngin' Tut 59, Hotrod Lincoln, Hanks custodian), 65 guests, and 2 robots.
Topics128,066
Posts1,055,871
Members48,428
#551999 07/02/2009 5:32 PM
http://i231.photobucket.com/albums/ee39/h4040510/1955%202nd%20Series/Qjet.jpg
I am missing parts from the heat spring in the manifold to the carb, but I don't know enough about a 350 to know what should be there. Anyone have a photo or parts list that shows the correct parts? Also, are the missing parts something that the FLAPS would have in stock or it is junk yard time?
Hugh
There should be a rod going from on that spring to the carb, and the cover is missing... I'm trying to remember what else to look for. It has been a while since I dealt with one. I think I may even have the whole setup for the thermostatic choke. If you can give me a few days I will look around and see what I can scrounge up, but I think I have all the parts around here.
Edited to add.... If I have all the parts then you can have 'em if you want them. I'll let you know what I find.
1963 Chevy C20 Longbed Stepside
1978 Chevy K30 Custom Deluxe
Bears63 #552010 07/02/2009 5:53 PM
Bears63
I will take all the help I can get. I will be out of touch until Monday, 6th. Have an great 4th.
Hugh
Well, Hugh, I looked around and I no longer have the parts for that choke setup. I guess I got rid of them. One thing you could do is try to find a manual that shows the setup. I'm not sure what it was available on, but I know for a fact that a '68 Impala w/ a 327 and Quadrajet had that setup. That was where mine came from. I hope this helps some. Sorry I couldn't be of more assistance.
