1 members (Hotrod Lincoln), 79 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#551847 07/02/2009 4:20 AM
I have a 1952 gmc 1/2t that I want to make into a chevy by replacing the hood, grille and panel in front of the radiator. Are the front fenders the same between a chevy and a gmc?
wibas #551858 07/02/2009 4:44 AM
Front fenders are the same except for the built in parking lights on the GMC fenders. Why would you want to change? I used to like the Chevrolets over the GMC'S but i now like the GMC'S better and they are fewer out there.
GMONIZ #551863 07/02/2009 4:53 AM
Are the radiator supports different too, or do you not need to change that for what you want to do??
Grigg #551905 07/02/2009 6:47 AM
A GMC original radiator will have a fill neck on the side of the tank and a piece went over the top of the tank. If you are just interested in having Chev stuff showing, you could probably keep the GMC radiator.
crenwelge #552032 07/02/2009 7:07 PM
Front crossmember on the frame is different to mount the GMC motor. Once you start making changes you may need to go deeper than expected.
OldSub #552107 07/02/2009 10:55 PM
If it ain't broke don't fix (change) it!
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
