| | | Forums66 Topics128,078 Posts1,055,939 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 28 New Guy | | New Guy Joined: Dec 2008 Posts: 28 | I have a 1952 gmc 1/2t that I want to make into a chevy by replacing the hood, grille and panel in front of the radiator. Are the front fenders the same between a chevy and a gmc? | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Front fenders are the same except for the built in parking lights on the GMC fenders. Why would you want to change? I used to like the Chevrolets over the GMC'S but i now like the GMC'S better and they are fewer out there. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Are the radiator supports different too, or do you not need to change that for what you want to do?? | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | A GMC original radiator will have a fill neck on the side of the tank and a piece went over the top of the tank. If you are just interested in having Chev stuff showing, you could probably keep the GMC radiator. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Front crossmember on the frame is different to mount the GMC motor. Once you start making changes you may need to go deeper than expected.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | If it ain't broke don't fix (change) it! | | |
