| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 11 New Guy | | New Guy Joined: Mar 2006 Posts: 11 | Hello, I bought a 33 1/2 ton a month or so ago....not driven it much until recent. It gets hot after only a few miles...I removed the stat housings suspecting a faulty stat and WOW...no stat. Is there suposed to be one?
I need to mention it has only a two blade fan!!! Is that correct.Also the radiator isnt original but appears Larger....my guess is that would be an advantage.. Could the manual spark advance contrbute to this?
Thoughts on how to cool down??
Thanks guys
mike
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I'm not exactly sure, but there should be a thermostat I would think. Every old car and truck I've ever taken apart, is always missing the thermostat. Why people leave them out it beyond me. Your shop manual should tell you this info. The 34 manual has this to say: http://chevy.oldcarmanualproject.com/shop/1934/34crm118.htmAhh, you only need one if its cold! | | | | | Joined: Mar 2006 Posts: 11 New Guy | | New Guy Joined: Mar 2006 Posts: 11 | Hello, Thanks for the reply, Would you suppose without a stat the water moves to quickly and never disapates the heat...I noted it calls for a four blade fan..humm logic says thats 50% more air..
mike
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I have not personally experienced it (because I've never left the thermostat out) but I've read that the lack of restriction does in fact increase the likely hood of overheating for the reason you mention.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You need to sort out the heat problem before installing a thermostat. I would guess that you have a blockage somewhere, maybe in the rad. If the fan is not correct than that could be part of the problem.
I think in my 1935 manual there is a diagram of the engine without a thermostat. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | yes, without a thermostat the water velocity is too great to be able to pickup heat. Also, I would guess there was an overheat problem to begin with and the prior owner pulled the T-stat to get bye for a short period. My guess the rad is plugged..
I would flush the engine, replace the T-stat and have the radiator serviced. While at it, it would be a good time to change the water pump as well. As regard to the two-blade fan. I do not know what was original, however that sounds not right.
| | | | | Joined: Mar 2006 Posts: 11 New Guy | | New Guy Joined: Mar 2006 Posts: 11 | Hello, Thank you all for the advise...now I go to work... Mike
mike
