2 members (klhansen, 1 invisible), 88 guests, and 5 robots.
Topics128,126
Posts1,056,356
Members48,441
Apprentice
Apprentice
Hi Guys
I am redoing the wiring on my 51 styleline. I was wondering what is the best way to ground the fuel sending unit.
I have installed electric wipers from Newport and connected them to the fuse panel but they do not work. I have checked checked the switch to see if it is getting power and it is but that is about it.
any ideas?
the sending unit should ground itself via it's mounting screws, otherwise just run a wire from one of those screws to a good ground spot .... might check the wiper motor direct from a battery and see if you got a defect, and it may need a ground wire, if it has rubber mounts
