| | | Forums66 Topics128,120 Posts1,056,321 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 43 Apprentice | | Apprentice Joined: Sep 2006 Posts: 43 | Hi Guys
I am redoing the wiring on my 51 styleline. I was wondering what is the best way to ground the fuel sending unit.
I have installed electric wipers from Newport and connected them to the fuse panel but they do not work. I have checked checked the switch to see if it is getting power and it is but that is about it.
any ideas? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the sending unit should ground itself via it's mounting screws, otherwise just run a wire from one of those screws to a good ground spot .... might check the wiper motor direct from a battery and see if you got a defect, and it may need a ground wire, if it has rubber mounts
Bill | | |
