2 members (lumbersawyer, JW51), 55 guests, and 0 robots.
Topics128,080
Posts1,055,945
Members48,430
#551549 07/01/2009 1:31 PM
Hello,
I bought a 33 1/2 ton a month or so ago....not driven it much until recent.
It gets hot after only a few miles...I removed the stat housings suspecting a faulty stat and WOW...no stat.
Is there suposed to be one?
I need to mention it has only a two blade fan!!! Is that correct.Also the radiator isnt original but appears Larger....my guess is that would be an advantage..
Could the manual spark advance contrbute to this?
Thoughts on how to cool down??
Thanks guys
mike
Morris #551567 07/01/2009 2:51 PM
I'm not exactly sure, but there should be a thermostat I would think. Every old car and truck I've ever taken apart, is always missing the thermostat. Why people leave them out it beyond me.
Your shop manual should tell you this info. The 34 manual has this to say:
http://chevy.oldcarmanualproject.com/shop/1934/34crm118.htm
Ahh, you only need one if its cold!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Mr. Lang #551586 07/01/2009 4:14 PM
Hello,
Thanks for the reply,
Would you suppose without a stat the water moves to quickly and never disapates the heat...I noted it calls for a four blade fan..humm logic says thats 50% more air..
mike
Morris #551612 07/01/2009 6:02 PM
Ex Hall Monitor
Ex Hall Monitor
I have not personally experienced it (because I've never left the thermostat out) but I've read that the lack of restriction does in fact increase the likely hood of overheating for the reason you mention.
Tiny #551725 07/01/2009 11:49 PM
You need to sort out the heat problem before installing a thermostat. I would guess that you have a blockage somewhere, maybe in the rad. If the fan is not correct than that could be part of the problem.
I think in my 1935 manual there is a diagram of the engine without a thermostat.
1951 1 Ton Completed
truckernix #551726 07/01/2009 11:57 PM
yes, without a thermostat the water velocity is too great to be able to pickup heat. Also, I would guess there was an overheat problem to begin with and the prior owner pulled the T-stat to get bye for a short period. My guess the rad is plugged..
I would flush the engine, replace the T-stat and have the radiator serviced. While at it, it would be a good time to change the water pump as well. As regard to the two-blade fan. I do not know what was original, however that sounds not right.
Scott Danforth #555631 07/14/2009 8:33 PM
Hello,
Thank you all for the advise...now I go to work...
Mike
mike
