0 members (), 80 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
There is a yellow wire coming of the HEI in my 63 GMC (327 engine) Does anyone know where that wire goes to? Does it go to the ignition switch (if so which leg) or does it go to the battery. Thnaks for any help!
Shane Hamilton
Warrensburg Missouri
PS, my truck is close to being road ready for the first time!
is it o.e ?
1966 Chevy C/60 Wrecker
Story in the Gallery
Pictures on Flickr
It don't rust if you run it hard enough
HEI has to have full 12 volts during start and ignition to work at its full potential. It will work with less voltage, but whats the point of that, you want the hottest spark you can get and that requires full voltage.
Theres lots of ways to get there, this is how I like to wire them,
1) use 12 gauge wire, color is your choice
2) one wire from the (R) terminal on the starter solenoid to the (BATT) terminal on the HEI cap
3) one wire from the ignition terminal on the key switch to the (BATT) terminal on the HEI cap
You can splice the wires together at any point up to the cap. Wire from the starter is hot only when the starter is engaged, the second wire becomes hot as the key is switched back to run. Use new wire and limit your connection and splices.
Joe
2) one wire from the (S) terminal on the starter solenoid to the (BATT) terminal on the HEI cap
Joe
if you splice the start(s) and ignition together the starter will not stop turning after you let go of the key
Pictures on Flickr
That is fantastic! Thank you all so much!
Shane
Warrensburg
Quote
huh??
i agree w/ alex
i use a 10ga wire
and it's a not me VERY BAD IDEA nono to splice any wires to the HEI !!!
Jim & Caroline
Riding in the Passing Lane
If you are using a GM factory HEI you need just one 12 gauge wire direct from the ign. term. on the ign. switch to the B. term on the HEI unit. If you are using an aftermarket unit you need the directions from the manufactor. If you hook a tach to it use the tach. term on the hei. A small gauge wire is fine for that.
1972 Chevy c10 Cheyenne Super
You guys are right, I should have said the (R) terminal on the starter. I went back and changed the post above. Points are wired this way. Sorry for the mistake.
You can use just one wire from the Ignition switch if the terminal stays hot during start, some don't.
Joe
IT WORKED IT WORKED IT WORKED! ThANKS!
Shane
