| | | Forums66 Topics128,038 Posts1,055,585 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 27 Apprentice | | Apprentice Joined: Feb 2008 Posts: 27 | Installing Jim Carter fiberglass running boards. Boards do not line up very well with supports. Any tips or directions for a decent fit? | | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | What year of truck?? How far out are they just a little or a lot? Can you oval out the slots in the supports a little to allow you to get the bolts through? Maybe bend the supports coming off the frame. Does the rear fender need to be slide back and or forth? Quite a few different things you could try. Let us know how it turns out and pictures are worth a thousand words.
38 original 48 panel 59 stepside 46 in the back forty
