0 members (),
134
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | I finally got my truck out on the highway. I did a short stretch about 2 miles between exits. I think I could have done a little better if I gave it a little more time with my foot on the floor.
The road was pretty flat and I got 56 MPH out of the 3/4 ton with 4:57 gears. I have larger than stock tires so I used my GPS to track the speed. It tells me my speedometer is off by about 5MPH depending on the speed. I hope to swap out the differential for a 4:10 soon and get a front end alignment. Then I think she will be "modern" road worthy.
Rich
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | It's those new emblems that made it go faster. that gps is amazing stuff isn't it. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Most guys are afraid to wind 'em that high. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | They were driven 60 in the 50's on roads that were straight enough to drive 60. If your rods are shimmed right and you have enough oil in them, it doesn't hurt them. My father used GMCs because of the pressure oil and precision bearings, but other than that there's not that much difference. The noise scares many people these days. Steel fans with no fan clutch and solid lifters and no insulation under the hood makes noise, but that doesn't mean anything is about to fly apart. | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | My concern was that my mechanic (me) has had no previous experience putting an entire truck together from its basic parts. Every nut, bolt, wheel bearing, tie rod and motor mount was installed by the cheapest labor I could find (me again).
I need a front end alighnmet but I was suprised that the front end seemed to smooth out as I past 50mph and she handled better than I thought.
Monster - those emblems looked real nice with the wind blowing over them.
Crenwelge - This is a 3/4 ton with a 216 and 4:57 gears. I was suprised I could get it over 50. Your right it was a little noisy but not bad. I insulated my cab pretty well, floor, ceiling, back, firewall...I am sure it could have been worse.
I can't wait to take her out again...if it eve stops raining here. We have had rain 4 out of every 5 days for the last 2 months.
Rich | | | | | Joined: Mar 2008 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 54 | I don't think you can find lower numerical ratio gears for a 3/4 ton rear axle. I ended up adding a Gearvendors .78 overdrive to my 3/4 ton and now I can cruise at 70. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Joe, your truck is gorgeous | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Joe, I have an Eaton HO52 rearend. The differential from the Eaton HO72 should swap out. Those were made with 4:10 gears in the early 70s. There are a few bolters on here who have done it. I am on the search for an Eaton HO72 to try it myself.
I found one at eatwestautoparts.com. Just aing for them to confirm the gears before I buy it.
Rich
| | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Yeah Joe that is a gorgeous truck
| | | | | Joined: Mar 2008 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 54 | Thanks Rich and 53 Monster.
I wasn't aware that the 53 had a different rear end. Mine is a Dana in the 51. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I would hate to see many years of research and discussion on the forum distorted by misinformation so unless I’m really misinformed myself, the Eaton HO72 uses exactly the same carrier as the Eaton HO52; it is the 1-ton version of the axle housing however. The differences being in the backing plates brakes and drums. There was never a 4.10 available in the Eaton HO72 and in this version of the Eaton rear axle you are most likely to find a 5.17 gear ratio and occasionally the option of a 4.57 gear ratio. There have been many discussions on this subject over the years and by reviewing the archives you should be able to verify this. The 4.10 gear was used in some 68-72 3/4- ton trucks with automatic transmission. Mine came out of a 1970 3/4-ton V8 automatic pickup. Very nice looking truck Joe, but if your 51 has a Dana rear axle in it then it has been changed from what was originally installed at the factory. Your single picture does not indicate what engine, transmission, rear axle was installed in the truck but I would assume that if it has a Dana rear axle that the engine and transmission have also been upgraded. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Ahh, another 216. I'm not surprised you can do 56. I've never taken my truck over 50, its a 216, with 5.14 rear, being a one ton. It will cruise at 50 mph with 2200lbs in the box. I generally drive 45mph though.
Looks great Rich.
| | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | The 4.10 gear was used in some 68-72 3/4- ton trucks with automatic transmission. Mine came out of a 1970 3/4-ton V8 automatic pickup. That's where I am trying to get mine. I have a line on a 72 3/4 ton V8... not auto though so thay are going to pull it apart and let me know the gears before sending it. | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | maybe I mis-spoke on the HO72 confusing it with the year which is 72 | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | If it's not an automatic then chances are it is the same as the gear in your truck, a 4.57. DG
| | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | | | | | | Joined: Mar 2009 Posts: 3 New Guy | | New Guy Joined: Mar 2009 Posts: 3 | Could you please explain what gearvendors are and how they work? Thank-You, Jimmy D> | | | | | Joined: Mar 2008 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 54 | A Gearvendors is an overdrive unit that bolts on the back of the transmission to give a .78 ratio in 2nd, 3rd, and 4th gear. You end up with 7 speeds, although I've never really used it in any gear but 4th. Here is their web site. http://www.gearvendors.com/index.html | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Joe, Is that .78 really $2895 or am I lookinag at the wrong thing? Rich | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Nope, that's it. The Gear Venders unit is very spendy. The Ranger Overdrive is another option along that line. Less expensive, but still requires driveshaft alterations to work, plus a hole in the floor for the shifter.
Bill Burmeister | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | You fellows better catch up.Had my 51 going to Datona the turkey run this past turkey day 130MPH on the GPS.No problem.backed off or could have gone a little faster.9'ford rearend,700r4tranny,350cu thats pushing375hp
dan-pa
| | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | No, thanks, dan-pa. I like 50 - 60 mph for a fast cruise, and I like the song of my in-line six.
There are times I will run balls-to-the-wall, but they are few, far between and limited to very lonely, twisty mountain roads when I am alone on my motorcycle. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Mar 2008 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 54 | Rich, the Gearvendors is expensive, but you don't have to change axles and can eliminate the center bearing in the drive shaft due to the 20 1/2" length of the Gearvendors unit and use a single drive shaft. Unlike the Ranger overdrive you don't have to cut a hole in the floor for the shifter since the Gearvendors is electrically operated. I used the throttle knob on the dash remounted on a push-pull switch to activate it. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Had my 51 going to Datona the turkey run this past turkey day 130MPH on the GPS. In this part of the country they don't hand you a ticket if you're caught doing that kind of speed, they cuff you. I've run three figures in a pickup. I guess I'm old now, the thought no longer interests me.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | dan-pa, do you have any pics of your truck you could share ? sounds like you got a killer truck...
leonard | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Ranger overdrive in action. It's toward the end of the vid.
