0 members (), 144 guests, and 8 robots.
Topics128,186
Posts1,057,211
Members48,465
While stripping down the front end today, I removed the king pin lock bolts and tapped lightly on the king pins...to my surprise, they popped right out. They were well greased and came out with almost no force at all. With the tires/rims on, the spindles had a small amount of play and I was thinking of replacing the king pins anyway.
Since they came out so easy, does this mean I need the oversized? The ones I have are in good shape with no marks.
46,
It sounds like they are in good shape. I would clean the pin and the axle eye and do a wiggle test.
The spindle bushings, wheel bearings and a worn axle eye can all add up to movement at the wheel.
Read the kingpin article in the Tech Tips forum..it may answer some of your questions.
Stuart
You'd only need oversided if the bushings were ground down and the steering eyes holding them were hogged out. You might be the luckiest guy on the board with that deal. You'll have to clean out the grease to see if the bushings are still in there.
If the kingpins didn't fit really snug the last time they were changed, the grease would go up the side of them and thus they would not be rusted in place. If there is not a whole lot of movement in the pin while inserted in the axel, the lockppin will keep it nice and tight.
1951 1 Ton Completed
Thanks for the info...yes..Lucky indeed..I was surprised to say the least when they came out without using the BFH. I was pretty amazed..I expected to go to war with the front end.
