0 members (),
80
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 92 Shop Shark | | Shop Shark Joined: May 2006 Posts: 92 | I am replacing the 235 in my 51 Chevy Feetline. How do I install the distributor? I know the first cylinder shoud be at top dead center. Does the rotor point at that cylinder with the points open or shut? | | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | Two things, first, #1 is at top dead center, second #1 is on the compression stroke. Pull the spark plug and hold your thumb over the hole while a helper cranks the engine over. It might take a turn or two till you get a feel for what is suppose to be happening. When you feel compression, you know both valves are shut and you are on the compression cycle. Slowly turn the engine till you see the timing ball or marker. Turn a little more and you should see a second mark not far from the first one, a diamond stamped in the flywheel?? This is where you set the timing. Double check by looking in the cyclinder to see the piston at top dead center.
Now, drop the distributor in place with the rotor pointing at #1 hole. It really doesn't matter where its pointing as long as you install the plug wires in order, its just pointing at #1 is the norm and caps are marked this way. Hook up the coil, cap and wires just as if you are ready to run it. With the hold down still loose, pull the plug wire from #1 cylinder and install a spare plug in the wire and ground the plug case. Turn on the ignition to run. Twist the distributor body back and forth till you see the plug firing. Keep going till you get as close as you can with the distributor. It should take just a slight nudge to get it to fire. Once you are happy with it, tighten down the hold down bolt, plug in the #1 wire and you should be able to fire it off. Timing should be with in a degree or so of right on the money.
Joe | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | weltertm,
In addition to Joe's excellent explanation, I will add that the oil pump drive tang on the distributor must fit into the slot on the oil pump properly to not only drive the pump but for the distributor to seat fully into the block.
Stuart
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Once the engine is at top dead center on the compression stroke and the distributor is fully seated into the oil pump drive, turn the distributor clockwise until the points close. Attach the primary wire from the coil (-) terminal to the connector on the side of the distributor. Turn the ignition switch to the "on" position. Using a test light with the alligator clip attached to a good ground, touch the point of the tester to the connector on the side of the distributor. As long as the points are closed, the light will not burn. Turn the distributor housing counterclockwise slowly until the light comes on. This indicates the points have just barely opened. Lock the distributor down at that position and the timing is set. Starting with the distributor cap tower where the rotor is pointing, wire the spark plug wires in a firing order of 1-5-3-6-2-4 in a clockwise direction. Fire up and go! Jerry
