| | | Forums66 Topics128,088 Posts1,056,416 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 28 | I am looking for a replacement vacuum diaphram that controls the Hi / Low range in my differential. Here is a link to a photo of the part I am talking about. I'm new to this pohto link stuff so let me know if this does not work. <a href="http://s842.photobucket.com/albums/zz344/68buickdude/?action=view¤t=0302091132.jpg" target="_blank"><img src="http://i842.photobucket.com/albums/zz344/68buickdude/0302091132.jpg" border="0" alt="'53 truck 2 sp rear end vacuum diaphram"></a> Does anyone have one for sale? Does anyone know of a supplier for this part?? Thank you and best regards to all.
Phil" Plasticman" Stewart | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | What is the outside diameter of the diaphragm? For my '50 COE I found a diaphragm on Ebay that turned out to be larger than mine, so I wonder if it is the same as yours. For mine, I was able to get the part number and I found one at a Phoenix GMC truck center. They were as shocked as I that it was on the shelf. They surmised that it went on something newer and that is why they had it. I will be at my shop next week and if I have the diameter of your diaphragm, I will check and see if I have the one you have or I can give you the parts number. | | | | | Joined: Jul 2007 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 28 | Thank you for the information. I will measure the diaphram and get back with you in the next day or so. Best Regards, Phil | | |
