4 members (TUTS 59, dt235sd, cmayna, 1 invisible),
70
Mod | | | Forums66 Topics128,176 Posts1,057,122 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 117 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 117 | Just got done installing Classic Perfomance front disc brake kit on my 50 3100. All went well and it was a very well engineered kit. Got the brakes bled and all that was left was to put the wheels back on and go for a ride. Wrong. My wheels, which are not original but a kinda hot rod, reverse offset steel wheel (on the truck when I got it and I liked the look so I wanted to keep them) hit the caliper! I'm sure I'm not the first to run into this problem so how have you all before me handled this dilema? New front wheels come to my mind as the easiest and most likely correct thing to do but I'm not sure if they are available to accecpt the center caps I currently have and would like to retain. They are the type that snap over 3 or 4 "nubs" stamped around the raised center ring. Help please.
Chuck | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | This happened to a friend of mine. he now has wheels that don't take the centre caps. | | | | | Joined: Apr 2009 Posts: 232 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 232 | call Early wheel in calif. talk to Jason. If you want steel wheels he can make them with different offsets. Don't have their number handy but they have a web site | | | | | Joined: Aug 2005 Posts: 278 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 278 | Had the same problem when I changed my 1967 to 1972 disks. I used rotor/hubs drilled for six lugs so that I could keep the original 1967 5 1/2" x 15" wheels. Wrong! I solved the problem be using 1971 through 19?? four wheel drive 6" x 15" rims. Look stock and have three "nubs" for center caps. | | | | | Joined: Oct 2006 Posts: 117 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 117 | Found some of the 6x15's today at a local salvage yard. They came off of an early Blazer 4x4. Narrower that the previous but look good non the less and no rubbing problems. Thanks all for the input. Chuck | | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | 15 inch Corvette Rallys 8" wide will fit.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
| | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | the hoops on a disc brake wheel don't have the step that drum hoops have they are flat to clear the calipers. | | |
