| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 100 | Hi, There is a 4 speed 1954 Chevy 4 speed on ebay in the UK that looks similar to my 41 4 speed. Are the later gearboxes synchronized, or are they the same crash box as  the 41. Just wondering as I'm not getting any better with the crash box and might swap it out if it's not a major job. Thanks D
For those who believe, no proof is necessary. For those who don't believe, no proof is possible. 41 Chevy | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The 4-speed transmission became a synchro-mesh, helical gear transmission in 1948.
| | | | | Joined: Jan 2008 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 100 | Thanks, and is it interchangeable/compatible with the earlier boxes?
For those who believe, no proof is necessary. For those who don't believe, no proof is possible. 41 Chevy | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | In 1947 they made the switch halfway through the year so it may be a bolt in and maybe not. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The redesigned synchronized transmission case was wider, higher, and longer than the earlier 4-speed.
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The bolt pattern is is different between the old spur gear and the later Synchro. I think the the clutch housing from the later one will fit the engine, but that causes starter linkage problems. The change was done routinely 50 to 60 years ago, but then we had the luxury of having salvage yards full of stuff to make the change. | | | | | Joined: Jan 2008 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 100 | Thanks for the info. Looks like I'll have to practice more with the double clutch or look for a later engine and box.
Cheers
