| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | Is there any reason I can not use a self etching primer in patches? the idea is to prime as I go not leaving any bare metal behind. I found this "etch primer" in rattle cans. What about overspray, blending, should I go with an expoxy instead. I plan to sandblast and at least prime as I go. https://buyat.ppg.com/refinishProdu...tID=63817403-97a9-4ec8-98aa-d5ac0fb87258 I do not get a lot of time at home and most work is done on summer break 2 weeks or so at a time. Thanks Brad | | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | You have to be careful using any kind of rattle can primer. I have had rattle can primer lift when the top coat is applied. Try the rattle can stuff, but then a sealer over it before any primer/filler or top coat. I also don't completely rely of primer/etcher to make sure there is no rust buried. I first wash the exposed metal in a rust preventor, and then I prime. In any event, remember that primer will not hold up very long against oxidation penetrating it. | | |
