2 members (Materman, 1 invisible), 111 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
I'm currently tearing my 59 Apache apart so I can get the body work done. I have the Bed off the frame and I want to next start with the Cab and front end. I will be taking all the glass out and doors off..At what point would Bracing the cab become important. Would I only brace the cab if I were replacing sheet metal and doing welding or should I brace the cab regardless? I don't want anything to twist or become out of whack.
if you're cutting any structural areas like the floor or steps, bracing is a good idea, but a completely stripped sound cab is fine, the factory handled them that way
