0 members (),
135
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 84 | I'm currently tearing my 59 Apache apart so I can get the body work done. I have the Bed off the frame and I want to next start with the Cab and front end. I will be taking all the glass out and doors off..At what point would Bracing the cab become important. Would I only brace the cab if I were replacing sheet metal and doing welding or should I brace the cab regardless? I don't want anything to twist or become out of whack. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you're cutting any structural areas like the floor or steps, bracing is a good idea, but a completely stripped sound cab is fine, the factory handled them that way
Bill | | |
