0 members (), 106 guests, and 2 robots.
Topics128,115
Posts1,056,292
Members48,439
#549311 06/24/2009 5:08 AM
what are the pros and cons of these transmissions. And can they handle highway speeds?
A gearbox is a gear box, top gear is 1:1 ratio, same as most every other 'box that isn't overdrive.
My '40 has it's original 4spd , so after 69 yrs, I guess it handles the road just fine. In fact , I prefer it to the 3 spd, I like the little noise that comes from the straight cut gears , and I enjoy the skill required to slip the non syncro cogs quietly thru. Also its stronger than the 3spd of its day.
Now if it is the original engine you might be worried about , then diff ratios are to be considered.............. smile
Well it dont have the original engine it has a 1955 235 and I'm going to use a 14 bolt rearend out of a 1981 chevrolet 3/4 ton truck with 3.73 gears.
I have the original 4 Spd. crash box in my ’41, coupled with a ’53 PG 235. It seems just fine. I would say those straight cut gears are bullet proof. You will, however, need bigger speakers for your radio. But the whine does go away in 4th gear.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
