Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Guitplayer, Hush), 106 guests, and 3 robots.
Topics128,281
Posts1,058,471
Members48,490
#543 12/07/2002 4:31 AM
OK...I picked up a '56 Chevy 3600 LWB today. Yeah, I heard it running before the deal went down. Started easy and runs very smooth. The PO didn't recall what engine it is. The hood trim doesn't have the "V" on it, so I'm assuming it didn't come with a V8. Anyhow, the oil filter canister is on the left side if you are looking at the engine from the radiator and the starter is on the right. The water pump housing has a short hose routing the right head and another routing to the left one. It has a Rochester "2 Jet" carb and the air cleaner cover has a "dry element" sticker on it. I'll try to get some casting numbers tomorrow but was wondering if someone would know from that description. I'm in Reno and that's a bit higher than where it had been. It started a bit harder here and ran rougher and a LOT richer. This is my first TF truck and I'm looking forward to working on it.
Scott
1964 GMC 1002 Long Wideside w/305E V6 & sm420 "Blue Jeans"
1996 Harley Davidson FLHTCI
1981 Husky 250CR
http://community.webshots.com/user/gmc1002hf5669a
#544 12/07/2002 4:37 AM
It sounds like a factory 347 pontiac. They did come from the factory with Pontiac engines cool
#545 12/07/2002 6:46 AM
Ya know what...I *think* "347" is written in grease pen under the hood. I'll check in the am. Thanks Mechainiac, I appreciate the input!
Scott
1981 Husky 250CR
#546 12/07/2002 7:45 AM
Congratulations Scott, I am obviously envious.
Send David Hicks home - now!
"Better to be wrong and kill no one then right with mass graves" Albert Camus
#547 12/07/2002 11:22 AM
I have always read that GMC's used Pontiac engines. Chevy used the small block with the Buick Nail head V-8 offered in the larger trucks , the Pontiac in a Chevy is swapped in.
#548 12/08/2002 10:56 PM
I just re-read this post and I was somehow thinking of a GMC truck you were talking about.If it is a Chevy, the pontiac engine was a transplant.Are you sure it isnt a GMC truck with a Chevy front clip?
#549 12/09/2002 2:04 AM
Yeah, the VIN on plate on the cab is 3E56XXXXXXX and is the same VIN as the number located on the frame in the engine compartment. I'm leaning toward "it's an implanted engine" theory.
Scott
1981 Husky 250CR
#550 01/02/2003 10:55 PM
OK...I was able to snap a pic of the engine and head casting number. The head casting number is 522010. If this is familar to anyone, let me know. The link to the photo didn't work.
Thanks in advance.
Scott
1981 Husky 250CR
