2 members (Guitplayer, MickeyP),
70
Mod | | | Forums66 Topics128,021 Posts1,055,356 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 27 Apprentice | | Apprentice Joined: Apr 2008 Posts: 27 | Does anyone know what this pancake device is on my 1962 Chevy 235 6 cylinder. It is attached with a solid fuel line on a Rochester B Carb. It is directly connected to the fuel pump and I am assuming it is a gas filter. However all the filters I have looked at as replacements do not compare to this. Thanks in advance. http://picasaweb.google.com/Tom.Gann/RochesterBCarbPics# | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it doesn't look like modern replacements cuz it isn't  I'd guess it's a vintage aftermarket filter, but it may also be a pressure regulator, not factory for sure - I'm the curious type that'd take it apart and see, then get a regular fuel filter to replace it  Bill | | | | | Joined: Apr 2008 Posts: 27 Apprentice | | Apprentice Joined: Apr 2008 Posts: 27 | If it is not factory, what does a proper filter look like. I would like to stay as original a possible. Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Apr 2008 Posts: 27 Apprentice | | Apprentice Joined: Apr 2008 Posts: 27 | Thank you for the information. I took the device off the line and low and behold it was a filter. See http://picasaweb.google.com/Tom.Gann/RochesterBCarbPics#5349949881069775714It looks like a coarse stone material but I think it is brass. I plan on cleaning it and slapping it back on there. thanks again | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yeah, that'd be bronze i think, should work fine, just make sure to clean it on a schedule cuz ya can't see when it's gettin dirty
Bill | | |
