4 members (Otto Skorzeny, Aggie49, baldeagle, Cosmo), 89 guests, and 5 robots.
Topics128,021
Posts1,055,346
Members48,420
#548666 06/22/2009 2:05 AM
Apprentice
Apprentice
Does anyone know what this pancake device is on my 1962 Chevy 235 6 cylinder. It is attached with a solid fuel line on a Rochester B Carb. It is directly connected to the fuel pump and I am assuming it is a gas filter. However all the filters I have looked at as replacements do not compare to this.
Thanks in advance.
http://picasaweb.google.com/Tom.Gann/RochesterBCarbPics#
Tulsa #548673 06/22/2009 2:12 AM
it doesn't look like modern replacements cuz it isn't ohwell I'd guess it's a vintage aftermarket filter, but it may also be a pressure regulator, not factory for sure - I'm the curious type that'd take it apart and see, then get a regular fuel filter to replace it wink
Flxible #548787 06/22/2009 1:31 PM
Apprentice
Apprentice
If it is not factory, what does a proper filter look like. I would like to stay as original a possible. Thanks
Tulsa #548792 06/22/2009 1:47 PM
Flxible #548945 06/23/2009 12:11 AM
Apprentice
Apprentice
Thank you for the information. I took the device off the line and low and behold it was a filter. See http://picasaweb.google.com/Tom.Gann/RochesterBCarbPics#5349949881069775714
It looks like a coarse stone material but I think it is brass.
I plan on cleaning it and slapping it back on there.
thanks again
Tulsa #548981 06/23/2009 2:56 AM
yeah, that'd be bronze i think, should work fine, just make sure to clean it on a schedule cuz ya can't see when it's gettin dirty
