Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (Lightholder's Dad, Donf, JW51, baldeagle, UtahYork, rfs56trk, Pre '68 Dave), 31 guests, and 1 robot.
Topics128,005
Posts1,055,253
Members48,418
#548612 06/21/2009 11:38 PM
So I took 2 days off work to finish blasting the cab of the 52. Everything was fine until one of my compressors stopped compressing. It is a 20 year old Devilbiss. I took the head off and there was daylight between the cylinder and ring. This morning I cut a strip of copper flashing and re-sleeved the cylinder. I clamped it all the way around marked the end cut it and silver soldered the end. Then I filed down the solder and ran my hone through it. The top of the cylinder rolls out at the top so I was able to tap the copper over to keep it from moving down. I didn't expect it run at all much less blast for 6 hours. It managed to run all day without a burp. I guess it is time to start the search for a new one.
sounds like a satisfying fix. what do you mean new one? you said it's still running. eeeek
But my wife doesn't know it is fixed. I get a new one to add to the mix and she is none the wiser. I guess it will eventually die but until then I will be a sand blasting fool.
Moderated by  MNSmith
